stevedenver
ok, im trying to learn digital. I bought some old lgb kit, simply to dip my toe. I am planning on buying the massoth dimax system .....but I am having so little luck in accessessing the feature I want to, I am reluctant to do so until I can see some results. I have read the LGB central station instructions and the 55015 instructions several times. I understand what little they say.
I have read the loco pamphlets as to which numbers activate which functions. however, if simply push that number key on the key pad, nadda. same if I enter numbers over "9" in the lighted screen.
I have a 55006, central station type 3 (has dimax plug input on back as well as LGB bus), an 55015 (non parallel) hand control,
I have four mfx locos, the Sachsen mk I, Sachsen MkIV, and, the factory sound equipped version of the Franzburg (set to loco address 5 ) others all factory 3. I have several old version 1 frr diesels and I can run them ok (backwards and forwards is all they can do).
I haven't tried to reprogram anything, everything is factory default setting.
I am not finding things intuitive, but, I am assuming things ought to work. But, I am assuming my 55015 handheld can access functions.
heres what I know how to do and can successfully do.
I can turn the light on and off, and, I can run the locos both directions.
All function keys (1-9) blow the whistle, and, nothing else. with different keys,sometimes the whistles sounds once, sometimes long, sometimes repeats, sometimes it will blow continuously until I hit the 1 button. I am clueless as to why , other than...perhaps the handheld is sending series pulses (repeated commands).
I can change loco addresses between 3 and 5..!!!
question
1 is there a basic incompatibility due to the series commands of my 55015 handheld? ie is this simply worthless with mfx ?
2 if not, can someone walk me through how to ring the bell. (small steps, then ill see if I can do more). very anxtious to get steam sounds and sync smoke on the MkI eventually.
3 if the handheld 55015 is a problem, should I buy the dimax navigator?
4 should I dump the entire lgb lot and bite the massoth starter package bullet-$1500 US) . (seems pricey to access MFX functionality. yet, I really like the slow crawl I can achieve and being able to park a loco). Is massoth viable? I tried to access the german site and it comes up empty or several links are inactive on the site, such as sound files, some products are listed as unavailable, and other signs that make me worry .....
thanks
question
thanks
