If you trawl through this link you will find plenty of pictures of Concrete Mountains:-
http://www.gscalecentral.net/tm?m=217763&high=Ruschbahn < Link To http://www.forum.gscalece...=217763&high=Ruschbahn
Basically they are made with a Wood Framework to support Chicken Wire and Fabric. Best is a cotton based one such as Dust Sheets. This is then covered in Concrete, pretty stiff mix of areound 3 or 4 parts Sand to one of Cement with some Waterproof PVA added. You can also add some Concrete Black Dye as obtained from Wicks. I further Coloour up using Sulphate of Iron, used to feed Azaleas so get it from a Garden Centre. It makes your Concrete go Rusty. Heed the warning about getting on your path though.
There have been other postings of the method n this forum too.
Much cheeper than Rocks, though the addition af a few Rocks can vary the effect.
Good luck and please post your results,
