Switching output command allocation.
adamski
14 Jul 2016
70
8
48
kent
Good evening
Was wondering if anyone could help as struggling to program a massoth decoder due to the loco being fitted with a phoenix sound card using function buttons 1 to 14. So need to do the following use function key 16 to switch output A3 and use function button 15 to control A1 output on the massoth decoder I have seen it can be done is it cv 52 53 if thats correct what's the values as been working on this for hours and got know where fast
many thanks
adam
Neil Robinson
579
N W Leicestershire
A couple of questions.
Do you know the the decoder type and version?
Can you isolate the Phoenix unit from the power whilst you reprogram the Massoth decoder?
adamski
14 Jul 2016
70
8
48
kent
Hi Neil
Its a Massoth emotion xxl
I have the Phoenix sound card wired now on a switch to isolate it while doing programming to the massoth decoder
cheers
adam
Neil Robinson
579
N W Leicestershire
O.K. my notes show two versions of the Massoth eMotion XXL. Some of the function CV allocations differ between the two and neither match the CVs you mention
I suggest you switch the Phoenix unit off and read Massoth's CV 7. If it's 0 it's an early version, if it's 22 its a later version.
adamski
14 Jul 2016
70
8
48
kent
Its a early version not the mark 2 I think after reading its ccv number 111 and 113. then set valve at 15 and 16
cheers
D
Deleted member 4232
Guest
Moved
