SUSI INTERFACES
TONYWARD50
Tadpole sexing</br>
16 Nov 2009
541
7
North Dorset
C n anyone explain briefly what the advantages/ disadvantages are of having a decoder with aSUSI interface ?
If you have sound and a pulsed smoke generator, must you have aSUSI connection, or could you use a Massoth XLS instead ?
Confused of Dorset
stockers
3,795
66
Nr. Ashford, Kent. England.
You could indeed use a XLS, which will also take the pulsed smoke inputs.
The Susi interface is to conect sound and such like to basic controllers - it is intended to make them 'industry standard' compatible.
ntpntpntp
275
UK
United-Kingdom
As Alan has said, the intention with SUSI is to allow a decoder to communicate with other locally attached devices - such as sound modules or additional functions. Seems a great idea in theory, to be able to start with a basic motor decoder and add sound or whatever later (and be able to mix and match brands much like you can with decoders in general). However it doesn't seem to have really taken off so far, and will probably live or die depending on other manufacturers adopting it (which may depend on the licencing arrangements with Dietz?)
http://www.dccwiki.com/SUSI
muns
Well-Known Member
130
Southampton, U.K.
www.gardenrailoutlet.co.uk
Confused of Dorset
The latest Massoth decoders have a SUSI interface.
Do you have a specific pulsed smoke generator in mind?
TONYWARD50
Tadpole sexing</br>
16 Nov 2009
541
7
North Dorset
It is already built in to the Brawa loco and is an excellent performer
muns
Well-Known Member
130
Southampton, U.K.
55.5 said:
Confused of Dorset
When did Massoth start to fit them to XL decoders? (Thinking of fitting a sound only module to my Bachmann Shay which has an XL )
Hi Roly,
I am unsure exactly.... If you have a XL that uses a green PCB then it is too old, it has to be blue. I think the firmware has to be 2.3 but I am unsure - I will need to check with the guys at Massoth - I will also see if the firmware is downloadable for older XL decoders. What is the value of CV7 ?
The SUSI connector is ringed in the picture - its behind the blue capacitor. If I recall correclty CV49 bit 4 needs to be set to 0 for SUSI operation - again I would need to check.
Gizzy
36,169
2,284
63
Cambridgeshire
If you knew SUSI,
Like I know SUSI....
stockers
3,795
66
CV7 just shows the firmware number - its read only.
muns
Well-Known Member
130
Southampton, U.K.
Sorry Roly, I should have explained what CV7 is, thanks Alan.
muns
Well-Known Member
130
Southampton, U.K.
Right, I can now tell you that there is restricted SUSI support in an eMotion XL decoder with firmware version 2.2 (CV7=220). Full SUSI support is available from version 2.3 (CV7=230).
Currently the firmware (v2.3) is not available in a form suitable to perform a firmware upgrade.
