idlemarvel
Neither idle nor a marvel
My first real "design and build" 3D printing project was to create a working Sh0 / Sh1 line protection signal. These are often found on German railways in stations and shunting yards. Here is a picture of a prototype:
And here is an explanation of how they operate:
Protection Signals
Here are the parts I designed before assembly:
And this is the final assembly:
In the slightly out of focus picture you can't really see the wire from the base to the signal head, but I can see it needs a bit more work.
And showing Sh1:
As you can see I have designed it to fit on top of an LGB signal motor assembly as that already provides a compatible mechanical signal actuator. It is hard to obtain those without buying a complete signal so phase 2 is to design a cover to fit on an existing simple LGB point motor.
I will put the STL resource files on thingiverse when I am satisfied with the design.
Protection Signals
And showing Sh1:
