ge_rik
JonathanResin D Etre Ltd said:It's a nice little block, but sadly VERY small when compared with 15mm/ft irish NG. I've never yet had time to prepare a datasheet, but wheelbase is 56+58mm and wheels are approx 37mm diameter over tread.
Thanks that's really helpful. The block may not be right for one of the larger Irish tanks but methinks it would look OK for a 15mm model of Southwold's 0-6-2 Wenhaston.
(Image from Southwold Museum website).
Wenhaston had a wheelbase of 3'7" (ie 53.75mm) and 3'8" (ie 55mm) and wheel diameters of 2'6" (ie 37.5mm) - which I think I could get away with. Although the wheel centres would be closer in 16mm scale (57.33 and 58.67) the wheels would be a bit too small (ie should be 40mm in 16mm scale). I think smaller wheels are more obvious than having the wheel centres slightly out, though. Only drawback is I'd have to construct the @*##$ valve gear! Rik
