Running Sierra sound with lithium ion???
paul delany
30 Mar 2018
238
Dublin Ireland
Hi folks I'm moving to battery power, my problem is I'm feeding the left and right track imputs on my Sierra board with the crest receiver motor +and motor - pcb pads In order to give the Sierra a reference voltage, but?? As Greg said in his post anything above 12v and the sound chips are over heating, tried to use a variable resistor set for 30 ohms but varies too much,, and help appreciated please.
GAP
14 Jun 2011
4,061
947
Australia
A "buck converter" would be you best bet.
This one is adjustable and take wide range of input voltages.
paul delany
30 Mar 2018
238
Dublin Ireland
Hi OK, I need some explanation here as I thought I understood the Sierra board basics? How is the motor v output over stressing the sound chips? What am I missing? The start up voltage for a shay motor is roughly 9 volts? What am I missing here?
paul delany
30 Mar 2018
238
Dublin Ireland
paul delany
30 Mar 2018
238
Dublin Ireland
Track voltage is 14.5 or what ever, motor + and motor - are feeding my Sierra track pickup imputs, so why is it over driving the sound processor S??
3,525
The simple answer would be to use a '3S' rather than a '4S' battery pack..
That way you would not exceed the 12V limit of the sound card.
Your motor is fed a PWM signal. - The full 14.5V but switched on and off, for different amounts of time (mark-space ratio) it is this that controls the motor speed.
paul delany
30 Mar 2018
238
Dublin Ireland
Hi Philip wow I didint know that at all, so I can't step down the voltage to 12 v with a 5 watt 30 ohm resistor then?
3,525
No, because the voltage across the resistor will depend on the current flowing through it, so will vary, rather than being a constant value.
As the load on the motor varies, the current will change through the resistor (which is fixed) so the voltage will vary.
paul delany
30 Mar 2018
238
Dublin Ireland
Hi PhilP I'm greatful for you explaining the finer detail, 30 years ago I worked in a r+d lab with access to ossiloscopes etc, I didint know that the motor voltage was a pulsed one, so I guess il leave the motor voltage feed disconnected from the Sierra imputs and have no sense voltage and just be happy with the chuff sound affect.
paul delany
30 Mar 2018
238
Dublin Ireland
Or, a dc - dc buck converter at the initial pwr imput.
3,525
Just make sure it will supply enough power for the motor and sound in your loco.
Fred2179G
20 Apr 2017
1,060
186
USA
I used a similar converter in a tram that had a Lithium Ion 4S battery producing up to 16V when fully charged. My 12V ESC did not like that, so the converter keeps it happy. The tram is quite slow though!
paul delany
30 Mar 2018
238
Dublin Ireland
Hi, I'm going to go with some buck converters I'm assuming the best way to adjust them for bang on 12 volts would be under load with a small motor???
paul delany
30 Mar 2018
238
Dublin Ireland
hi fred what dc converter did you use i cant find any 14.8 to 12v converters
Fred2179G
20 Apr 2017
1,060
186
USA
Paul,, we may have confused you with the talk about fixed voltages. The one I used had a fixed output but a variable input. Like this one on US eBay.
paul delany
30 Mar 2018
238
Dublin Ireland
hi Greg i cant find a converter to convert 14.8 to 12volts
Hi Fred so.
I fitted a dc/dc converter board, LM 2596 , I then set the output voltage to 11.2 volts while the pcb had a load on it, I fiited to the electronics on my shay,, frustratingly, the motor output feed to the sencing part of the Sierra board is still causing the sound chips to overheat, even when I adjusted the final output voltage supplying the crest receiver with 9 volts.
So I'm giving up and doing away with the Sierra sensing voltage completely.
I don't know why the Sierra is overheating??, when I remove the motor sense feed wire, the Sierra performs fine.
I'm confused now
