Apologies misfired the post
This the previously posted picture is my Aristo 2-4-2ST
It is pretty close to an actual loco exported to Cuba for Sugar Mill work
I believe the chassis existed until about 2000 as a local conversion to diesel power
Wow awesome weathering job looks amazing..
Yep, mine's in an REA box and similarly does not have the extended roofThe Rogers came in two types, one with slope back tender and one with no tender. The tender one has a cab roof that hangs back further. Jack44's one is an early model without tender which I think was under the REA brand name. It has chrome plated wheels but later ones from Aristocraft had blackened wheels which I think tend to crud up more. The drives are interesting because each axle has it's own motor and gearbox therefore a good source for making frames with different axle spacing.
I'm not sure where they carried the wood or coal, I suspect it would be in a rear bunker. Some were used in short shuttle railways running in reverse therefore didn't need a a large fuel load.
I think the repaint looks very good, run it for a little bit and then dirty it up a little, I used parts of it on my logging engine, front pilot, and part of saddle tank on "Rosy", great looking engine. Tender, don't think it should have one, if so something on a single truck for fuel, engine already has water in saddle tank. Probably go for a rear coal bunker because of the straight stack. Not sure if factory engine had pickups on front/rear pilots or not but if not add them for better pick ups. Sharp looking engine, BillYes mine came in this same box but doesn't match the picture.
