Resetting to factory settings for LGB chip
adverse camber
2 Dec 2009
246
68
East Anglia
I have a LGB sumpter valley (now returned!) with a factory chip in it. It has a tendency to suddenly take off when parked in a siding for no good reason. I want to reset the chip to factory settings to see if that cures it.
I know that it is CV55 to do so but what value does one enter? 0 or 1 or something else?
Anyone else had this problem and found a way to cure it?
Thanks chaps
Adverse Camber
muns
Well-Known Member
130
Southampton, U.K.
www.gardenrailoutlet.co.uk
If i recall, set CV 55 to value 55
Gizzy
36,167
2,283
63
Cambridgeshire
Got the LGB 55045 Decoder Interface with software with my Lappy?
I can bring it to the MRC on Thursday....
Cliff George
17
City of Chelmsford
I suggest that you turn off the possibility of analogue operation via CV29. I had a similar problem and that solved it for me.
stockers
3,795
66
Nr. Ashford, Kent. England.
Not met the problem myself but I have heard that that fix, fixes it. Best of luck.
adverse camber
2 Dec 2009
246
68
East Anglia
Thanks I will try turning off the analogue 1st.
Dont know about you Garry but I will be at the AGM on Thursday. Guess you might be a bit lonely!!
AC
Gizzy
36,167
2,283
63
Cambridgeshire
AC
I'll be there too!
I'll bring me lappy along....
Gizzy
36,167
2,283
63
Cambridgeshire
Just had a look at my LGB 55045 MTS decoder software, but I can't see CV55 here?
Maybe I need to connect to the loco and read the values before I see it on the GUI....
Cliff George
17
City of Chelmsford
I would think that the button marked 'Rest all values to factory pre-set values' is the one you want, however before I did that I'd try setting the 'Analog running:' to 'locked'.
No - You have to read CV 55 in the "Single CV" read out (bottom left of the panel) - And write back the same way (CV 55 set to "55" is a reset)
This article has the relevant settings
http://www.gscalecentral.net/m206128
Cliff George
17
City of Chelmsford
Yes I'm sure using the single CV feature as you describe would work. Does not pressing 'Reset all values to factory pre-set values' do exactly the same thing?
Gizzy
36,167
2,283
63
Cambridgeshire
I've used the Single CV readout button once to restore sound on an MRC decoder, which are mapped differently to LGB/Massoth ones.
So it's possible to use the LGB product on other manufacturers decoder, if you know what CV to program....
stockers
3,795
66
Yep - that'll change CV29. Worth trying before a factory reset.
CV29 is one of the awkward ones - it controlls various functions. The LGB software breaks it down into separate components for you.:clap:
