Oh and on a power supply I would suggest using a 5 amp supply for the EPL system and even with that possibly a LGB EPL booster. When running trains in opposite direction's it's extremely important that the points throw reliably 100% of the time!! it gets very interesting otherwise. Make sure you use an adequate size of cable to carry the switching current. On my garden I was able to run six trains in opposite directions using the EPL system and very impressive it was too until a point would fail to switch then it got interesting in a bad way. Not trying to put you off in any way but you will need to be very careful in planning and fitting the wiring whichever way you choose to wire it, common return or separate return.
The line overall at the moment will total about 40ft, and the points at the passing area will be manually set at the start of each day's running. The loco will go straight on going out, as it were, and round the loop coming back.
