A GOOD friend has just given me a little diesel loco. It?s so ugly, it?s cute. It?s been scratchbuilt on an LGB motor block labeled 2317/6 which seems to be a block from a powered Tender. The builder obviously used an LGB steam loco cab and added a diesel hood. The cab arrangement is weird in that it has 2 side doors with seats behind them and then an open rear as per a steam tender loco. I have to decide whether to block up that rear opening or not.
Anyhow, I like it, so I need to do some battery power?.
Now the real problems are:-
There's no room for a speaker, except maybe in the cab roof.
All the 'cavities' are just too small for AA batteries. The space under the hood is only 90Lx40Wx48H. The 90mm long dimension is just too short for two cells along. It?s 48mm high where 55mm would have allowed cells to stand up. etc, etc?.
(That?s why when I build my own locos, they are dimensioned to fit batteries! )
I figured I had two options:-
A. Just use a simple forward/off/reverse switch. I measured that 5 cells will be sufficient to give about 25kph. I can fit the 5 batteries and switch in the hood OK.
B. Go for 2.4GHz full RC. If I use an existing transmitter, I only need a Receiver, ESC and servo+switch for direction. I?d need min 6 cells for this. But I can?t fit all that in the hood with the batteries. So I?ll have to put 3 cells in the cab disguised as tanks or something. Two more mounted vertically in the little side ?cupboards? ? I need to drill holes in the baseplate so they extend below the base. That leaves one or maybe 2 or 3 cells under the hood. If I can fit 3, I?ll have my standard 8 cells arrangement with simpler charging.
I even went searching the Internet for LiPo batteries which would fit better, but no luck.
In both cases, if I can fit a speaker in the cab roof, and it has enough volume to be worthwhile, I can use my home-made Picaxe sound system and it should fit in the hood in both cases. That will come later.
For the extra $25, full RC seems the way to go. So this is how it MAY fit.
More to follow?????
More to follow?????
