PWM Motor Controller
1,119
58
I recieved a PDF Model loco for Christmas. It has a 3V motor supplied with it, but no speed controller. Would a PWM type be suitable? I'm not particularly interested in any else other than manually controlling the speed for now. (It's easily disassembled for any upgrades). Would anyone have any advice on manufacturers? Or would any £5 hobby from ebay be any good?
2,910
Tamworth, Staffs.
The only thing to watch, is 3V is going to be quite a low voltage for many of the cheapy controllers..
I have some, but have not tried them at such a low supply voltage. They may also be too big, to fit the loco?
1,119
58
OK, cheers, I'll take a look at the physical size.
Rhinochugger
Retired Oik
3,654
North West Norfolk
There used to be a wiring diagram for a standard G Scale controller (when we were all G Scale Mad) and it was similar to Ivan's IP Engineering speed controller :nod::nod::nod:
I could never make them work, probably because I was using too many volts :oops::oops:
1,119
58
I'm going to look for a small radio controlled car to butcher, just see if I can do something with that
2,910
Tamworth, Staffs.
By all means do.. See if you can get one of the teeny, tiny ones, they sell at Christmas..
Problem with them all, is they are stop, or fast. - We need slow-speed control..
justme igor
17 Apr 2020
293
28
Netherlands Westwoud
Netherlands
JimmyB
It looks like a 2.4 gHz so they should not interfere with each other, but I am sure one of the others can confirm this.
justme igor
17 Apr 2020
293
28
Netherlands
Yes it is a 2.4Ghz.
I while ago i saw a forum member that had 41 of those rc units incl 41 (diesel) loco's, but i forgot witch section and who it was.
But i have no idea if it is similar to the one i have.
It would seem logical that they wont interfere with each other.
With best regards,
Igor
