I fabricated my own version of the door closing mechanism in my Pola engine shed. Instead of fastening the pulliing arms at the top of the doors, I felt that the center would be less resistance. I do not have a photograph to post at this time, but I will try to explain it as best I can.
At the center point of each door, on the hinge rail, I fabricated a pivot block from one of the Pola gray wall corner blocks. From these blocks, I ran a 3/32" diameter brass rod, bent at 90 degrees to fit into the hole in the block, back to another block fastened to each side wall about 2/3 the way back into the building. Now, when the doors move these rods are free to move. At this point nothing is keeping the doors open or closed. To the brass rods, near the ends that are farther back in the structure, I soldered a cross bar. This is what the locomotive hits when it enters the shed. Now, to keep the doors in the open position, I fastened springs from the side walls to the brass rods. These two springs keep the doors open. The only other thing I did was to attach a piece of foam to the cross bar that the loco strikes. I have a short film that shows the working doors. You will notice that the doors do not close all of the way. I have since corrected the issue.
http://www.youtube.com/watch?v=x5_8Nz-67og
