Morning All
I have had Planet T5s for some years, all with R6M Rxs working satisfactorily. But I now have an intractable problem with a couple of R6Ms.
If I need to replace them I want to be sure that the replacement model/versions are going to work.
The ESC supplier tells me that the problem is caused by the R6M putting out garbage on the throttle signal. I understand that means a non-zero voltage at rest. Does this ring any bells?
If you have an accessible Planet T5 R6M and a moment I'd be grateful if you could do a Test measurement for me please. With the R6M powered up, and the transmitter off, measure the voltage on the throttle signal (+) and negative (-).
Alternatively if you have a loose R6M I could borrow for a day I would be able to test it myself. I'd happily pay your postage.
Many Thanks
mike
Many Thanks
mike
