Madman
I need to take a closer look on the bench at this. I was working at installing a Piko 35265 Supplementary switch onto a Piko 35271 switch drive today. I removed the top plate from the switch drive, near the end, by removing one screw that holds it in place. Then I inserted the supplementary switch into the switch drive and secured it with the plate and screw that are part of the switch drive. It isn't a very secure fit. And when I tried the switch drive the supplementary switch would not light the signal I have wired through it, unless I pressed on the supplementary switch. And then only intermittently.
Anyone familiar with these?
