Beddhist
Motorcycle travel, trains
I have shouted myself a belated birthday present: the blue Pressnitztalbahn "Kamel". As I am building my layout with dead rails it will have to be converted to Airwire and I want to install a sound decoder.
Checking the Piko Harzkamel manual they say that it only needs a 2A power supply. If that is correct then I could use a Zimo HO decoder with this, as some of them are rated 2.5A continuous. This would work out a lot cheaper than a large scale decoder.
Has anybody ever measured the actual power consumption of one of these? I'm assuming that they are all identical under the hood, including the 2- and 3-axle bogie versions.
Then again, if I later want to add smoke I will go over that, won't I?
