Riograndad
I upgraded the water tower a few years ago when it came home from Glendale,the thing looked spindly and toyish but could be made to look the part so I made some modifications, adding just a few bits to the original model,I don`t remember posting it before so appologies if I did,being outside 24/7 has left it a little weather beaten and has been on my rountoit list for some time.The main difference is the amount of legs and cross spars to the base and were all knife grained before assembly although I did keep all of the original parts to reuse in the modification and bolts added for a little more realism,the water glass gauge was added but the stick on numbers have long gone so a new one of plastic numbers to be made and fitted,the spout has been fitted with balance weights and the action runs through a couple of boat rigging pulleys which do the job well,the rear of the spout needs repair after a huge wind storm sent it down the garden and broke the lug off the back and the elastic tank bands have stretched too far and long gone,the tank deck made bigger and appears more like it could hold the tank up now and a ladder added as the original never had one.It replaced a quick build balsa item that I threw together when I first started outside.All I have done so far is a glue test on some of the new tank banding and appears fine so its carry on and get it done. Pics show the original item and the upgrades,probably needs a repaint too
