Nicki &Frank S Sound Axle
shropshire lad
25 Jan 2010
4,552
12
Sunny Shropshire
Can you fit a Massoth sound axle to a Nicki & Frank S?
I can't see if the quadrant plates on the motion are screwed into the axle centre or not and don't want to strip it down til I'm ready to do the job
Cheers Colin
mike
Master at annoying..
4,457
Rossendale
yes, but ill ave a chat at phils!,or here, or there..i chat for cake
dutchelm
176
N Somerset
I've fitted one in a tender on a N & F. No problems.
Steve
I didn’t say it was your fault, I said I was b
1 Jan 1970
29,027
285
D.I.L.L.I.G.A.F
I hate to say what he may do for JD:rofl:
shropshire lad
25 Jan 2010
4,552
12
Sunny Shropshire
Cheers for that Mike (Dutchelm)
I'm looking to do some slow running videos so I need good synchronisation of the sound and motion. An engine axle is probably going to be better if possible
dutchelm
176
N Somerset
The standard axle supplied is only a replacement for short (inside bearings) axles. It is not long enough to connect fly cranks on the outside. You would need to make a special axle to take the magnet.
The synch on my tender drive is fine.
palmerston
trains
14
Netherlands, near Aachen ;-)
You will need the soundaxle from a croc or OBB diesel (spare part) AND the Massoth kit for the sensor and magnet. The old LGB sensor cannot be used with Massoth units.
