Surely there an easy fix to get more movement out the centre driver axle?
Yeah, which is great for my 1st radius curves, though I heard on the Newqida loco, it has trouble in getting around them, due to there not being enoughCallum, it is designed-in to the LGB engines.. From an 'engineering' point of view, the amount of 'slop' in the motion, and side-to-side play on an LGB loco is necessary, but seems horrendous.
Other manufacturers have addressed this by having a centre axle were the wheels do not have a flange, but are flat across the tread of the wheels.
The other thing of interest to manic Train Spoters is the difference of Numbers between the Side and on the Smokebox Door. Will drive them crazy! But I do agree for the price is a pretty good animal. If you can get rid of the R1's. Will give better running all round.
or continue to annoy the train spottersNot to mention rivet counting (oh sorry, I just have)!
My train spotting days are long gone (standing in Leeds City or Central stations). Long live Ian Allan R.I.P.
Once I got the magnifying lenses out I could see what you meant Jon! A little black paint and some white Letraset or Vinyl letters (numerals) will sort that - how could the inscrutables not open their eyes?
If removing the center flanges the axle may need holding up. I dont know how much flexibility is in these but if the middle axle can drop a bit the wheels will drop below the surface of the rail on sharp bends and derail as the bend straightens. Model locos with intentional flangeless middle drivers usually have the wheel held slightly above the rail surface.
Didn't spot that until you mentioned it! As for the radius ones, the layout is in a very tight location, so the R1 are sadly a must to make it all fit in. Hopefully one day though...The other thing of interest to manic Train Spoters is the difference of Numbers between the Side and on the Smokebox Door. Will drive them crazy! But I do agree for the price is a pretty good animal. If you can get rid of the R1's. Will give better running all round.
Ah, thanks for the info. Will have a look into itIf removing the center flanges the axle may need holding up. I dont know how much flexibility is in these but if the middle axle can drop a bit the wheels will drop below the surface of the rail on sharp bends and derail as the bend straightens. Model locos with intentional flangeless middle drivers usually have the wheel held slightly above the rail surface.
The replacement wheels have arrived, not bad 12 days from Germany, I will now fit them and I will look at the side play of the wheels.
An initial brief look has revealed that there is a molded piece on the back of the wheels that is not present on the LGB wheels I compared them to which makes the distance of free axle shorter.
This causes the flanges to sit higher than the LGB ones when a side by side height comparison was carried out that actually allows them to overlap.
My thinking is that this molded piece can be filed down or the wheels could be tapped out along the axle and that will increase the side play.
Could I please ask someone who has an unmodified loco to weight it and let me know how much it weighs so that I can add extra weight to get it back to pre mod weight.
I will be installing a 9.6V battery (8AA NiMH), Peter Zenner advised that the motor will accept up to 10V with an ESC, Receiver and a servo from Hobbyking.
The R/C gear is what was fitted when the previous owner converted it to battery and .
And my LGB one weighs 3.0Kgs!Mine weighs in at 1.487kg with the stock battery, 1.175kg without.
Just managed to return the kitchen scales to the cupboard before SWMBO appeared!
