Hi, i got 2 receivers doing the same thing. on the P1 & P2 directional lights. If i join the lights up for a test at 3.5v & appropriated resistors all works fine. If i then reverse the polarity, the lights, the colours change ends. So! all is good. But when i connect to receiver terminals P1 & P2 i get red in the front & nothing in the rear when forward is selected. When i select reverse i get red in rear & nothing in the front. The led's are 2 pin red/white revers polarity to change colour. This is the same on 2 x MR603 receiver's. Yet on a smaller loco using a DelTang, works perfectly. Any suggestions ??. Thanks
