I am using a Nav with a LGB 55006p, I recently decided it would be good to go wireless, so I bought the Massoth PC module to update the Nav so it can be converted to wireless, that failed I have tried three PCs on two diffrent operating systems and non can update the Nav firmware, all end with the read no data 117 error, but I can update the PC module firmware, so it is working, I can all so read and write CV's on the programming track OK.
I also bought the Switch Decoder 4K, if I connect it up to the programming track I can read the CV's OK via the PC module and the Point motor switches when it reads so that is working OK
If I use the Nav second function and tell it to switch the point motor nothing moves , it should and is on address 1 as its still set to factory defaults.
Beginging to think I have a naff nav or I am missing something basic here ? as apart from select an engine and operate it with the nav, it won't control a Switch decoder or up-date when teathered to the PC module.
