muns said:I believe the 1200T will be available in July and should be able to deliver 15A peak, 13A nominal.
From me the 1210Z and the 1200T will equate to exactly the same price as the 1200Z did.
The 1200T (prototype)....looks like the same case as the 800Z & 1210Z.....
Stainzmeister said:15 amps !
Enough to run 30 Buhler motor blocks simultaneously............or up to 15 twin motored locos.
Stainzmeister said:When the lads are round we sometimes have 4 trains running simultaneously off one handset (three circuits to go at).
When I run trains then I might have three running, but that's enough for me !![]()
PhilP said:Stainzmeister said:15 amps !
All from a hand-controller with only one knob, so one engine at a time..
Mind you, most people will not run more than one engine per handset!![]()
