Tap water may be fine for you Johnnie, but unless you live in an area with exceptionally soft water, the boiler on your loco will eventually fur up like a kettle - except it won's be as easy to clean. Have a search on the forum about water, because this topic comes up fairly regularly.
However the quick answer is either filtered rain water, or distilled water obtained from a de-humidifier. You can buy a de-humidifier cheaply and it can be used to dry out rooms or the washing while it makes distilled water for your loco!
There's been a lot of discussion on the forum and others about the whys and wherefores of de-ionized water, but in the end buying 'distilled' water rather than making it yourself is usually a costly exercise.
Try here http://www.gscalecentral.net/tm?m=61152 or here http://www.gscalecentral.net/tm?m=2477
Steve
Steve
