LGB 'Spreewald' 2-6-0 Tank
duncan1_9_8_4
Garden Railway Operator/Real Life Signalman
On behalf of my dad, the above loco has a bit of a problem.
The headlights and cab light will not work!
The loco is dcc controlled via a LGB chip.
The lights will also not work on analogue too.
Under DCC opperation the lights will not respond to been turned off and on........... they just remain unlit, the same goes for analogue too.
The bulbs though, do work when taken out and put to a power supply.
HELP......................! please, many thanks.
try reversing the plugs on the chip.. ie, put the back l;ights in the front lights sockets.. see if its the chip, or a wire ..
it could well be, or, a broken wire if ur lucky.. hense swapping the plugs round, it will show if its the chip/or a broken wire..
no , but.. with a bit off work, you can reverse the wires form the motor block, and run the chip backwards..
