Airbuspilot
There are 4 reverse loops on the G scale DCC layout I am working on, three setup by someone who is no longer around and one by myself. The three existing loops have a sensor track around 20 cm long, I have rewired all of them as the cables were looking sad. The fourth loop came from a new box where I discovered (for the first time) sensor track of about 3 cm and used this in the last loop.
I have been told the longer sensor track is required as some longer locos with two bogies have problems when they cross over. In reality I have found different problems between each of the three existing sensors, small locos work well on some and stop on others while the long locos stop on some sensors and in one case shorts the sensor. So far it seems the LGB track length of 3 cm works but this is on a fairly steep gradient which some locos are having a problem climbing, I don't have reliable information to warrant my picking up and modifying the track on the other three loops.
Does anyone have experience of the LGB Reverse Loop sensors? I assume the short lengths are made this way for a reason and I will probably need to modify them all but I don't want to make changes until I know what I am doing.
I made a simple phase sensor to test the track phase, looking at the sensor track it seems to switch phase continuously, I cannot find a circuit diagram and I'm not sure why it does this?
Robin
Robin
