LGB Analogue Controller 51070
Buy now for 0 USD
I am looking to get rid of the above item after converting to MTS. It is in good condition and without box. Looking for £60 plus postage, or will consider swap in exchange for an item of US Narrow gauge stock, perhaps a Bachmann Tanker etc.. SOLD
Re: LGB Analogue Controller 51070
I lack knowledge of this - does the controller require a transformer? Or would it work off a 12v DC (battery) supply?
Sorry for the questions but at 5amp I am intertested ;D
You would normally buy it with an additional LGB Transformer (LGB 50110)
http://www.champex-linden.de/lgb_produktdatenbank_d-e/produkt.nsf/bede3443927b513dc125691c0045fb87/693699f5d723a8a0c1256936003d15ee02ec.html?OpenDocument
Thus your 12V battery will have the current but not the voltage, but it should work Mick....
Thanks for the link Gizzy - I see (as you would expect I suppose) that the output is AC. So I suppose (again) that the rectifier is in the controller? How would it cope with DC input?
The control I use for my trailer layout has a 3amp max (simple small pot and Darlington transistor) - hence my interest in the 5amp rating of this LGB one.
Mick, here's the linky for the Controller that Duncan is selling;
http://www.champex-linden.de/lgb_produktdatenbank_d-e/medien.nsf/medien/BAECE1BF74F5599D8525693100631366/$FILE/51070_022003.pdf
You can feed it with DC upto 24V....
Most of these controllers have a built in rectifier to cope with AC. No problem if you put in DC except you loose a few volts in the rectifier. If you only start with 12 volts you may have a problem.
Any chance of having a 12 v & a 6 v battery in series so you start with 18 v.
Thanks Gizzy - sorry for being a pain in the proverbial. All is now clear.
Mike - yes I could probably put 6 & 12 together but I suppose it would depend on what actually comes out of the controller as I mainly run Bachmann stuff. I'm using a 55amp battery which delivers 13.5v for most of the day but the track voltage is between 11 & 12volt. Some of my Artisto locos go like a rocket on that!
Hi Paul. I would like this please. Have tried to send pm but can't get it to work ATM. Could you try from your end please?
No worries Mick, glad I could help....
Hi Mike - I had declared an interest in it and was just wanting to increase my knowledge before I committed to purchase it! However, I'll step away from it if you want it.
Thanks everybody for your help.
Hi Mick. I'm happy to await your decision whether to purchase or not. I have enough for my immediate needs, but an extension is looming!!!!!!!!!!
Hi Mike - you go for it.
It's a bargain - but my garden line needs a revamp and I doubt it will be this year!
The trailer layout will be laid up for the winter at the very end of this month and I have to make a decision about continuing to take it to shows. I was thinking of the increased amperage but I do have a 10amp Train Engineer (from Ross) which is capable of servicing both lines ;D
Regards
Thanks Mick.
Paul, I have 3 PM's in my outbox which cannot be delivered. Your profile settings may be preventing messages being accepted.
WOW just got back from work and thread overload :) I have received your messages Mike, am I correct you and trammayo have reached an agreement, don't want to sell to the wrong person....?
Yes agreed - Mike can have it.
Hi Paul. Pm sent re payment.
Hi Paul. Time honoured phrase. Cheque's in the post.
Mike.
