QC Rwy.
Some progress today.....a lot of small cutting and shaping of the components to get the best fit. First off, Greg reminded me to make sure the center of the cylinders were in line with the driver Axel centers.....good catch!   I had to make a couple of cuts dropping the saddle down about an 1/8th" to get it in line.....easy work, just takes a bit of time.
Next up was fitting a bit of foamed styrene under the boiler to fill the open space and raise the boiler just a bit to set it level. I place the tank and the cab front in place to show how it's coming together.......All the subcomponents will be built first and then attached with glue if permanent and with screws if necessary to disassemble later. (for battery and sound components)
Here's a couple of pics showing the rear of the cab wall and how I cut out a section of the front cab wall to allow the boiler to pass thorough allowing a much stronger joint than just a plain "butt" joint.
