I recently bought a copy of the US Mag Model Railroader and there was a super article about `Carving Realistic Stone from Foam`. I thought that this had possibilities in the Garden so I purchased a sheet of the thickest that I could find which turned out to be 3 inch Ecothirm. At £30 for an 8 x 4 ft Sheet I reasoned that it was not too bad value to get a couple of big lumps of Mountain from. I also used a bag of Postcrete for the first effort. Though much of that was used in making the Bricks Stable. I should have cemented up the complete thing before I put the Ecothirm in place. Well I have one more to do so will get it right on the next one.
Pic above is the Ecothirm before hacking. I used a Hacksaw Blade in a Stanley Knife Type of Holder to cut out a basic Hillside as below.
Then I made Brick Based Sides to hold the Ecothirm in place as below. This is the one that I have done so far and it is these Bricks that I should have cemented in place.
Below is the other area where I will use the other half of the Hills.
The results of much hacking, wire brushing and general abuse of the Foam gave me this result (below). My main concern was to ensure that all the Paper and Silver Coating was removed. The Coating is Silver Sheet, Paper and then More Silver Sheet. Without a doubt the Wire Brush worked best, but I did hack at it all with. Dentist Tooth Hacker before I wire Brushed it all, this loosened and weaken the underlying Silver Covering to let the Wire Brush do its job.
The final job is to get the complete thing covered with Postcrete. I did this by laying the sheet on its side, watering with the Watering Can then just flinging Postcrete on the Damp Sheet. Let it dry for around 10 minutes and then you can do the other side. The Ridges were done when I put the sheet in place between the Bricks. The final result is shown below:-
Inevitably you will miss some bits and they will become apparent when you put the thing in its final resting place, no worries just use a Small Spray with Water and a Tadge of Washing up liquid, damp the area and throw Postcrete at it.
WARNING Use Rubber or Latex Gloves for all your use of the Postcrete, it is not good for the hands.
My final thoughts are that I should have made the end closest to the path somewhat wider, I could still do this by using some of the offcuts and may well do. No doubt the method would work very well next to a fence or wall. I have partially filled in the plot with earth and once planted out with Conifers and Rockery Plants the effect will be much changed. More views on this and the next one when I get round to it.
But what do you guys think?
