Template errors
  • Template public:thread_view: [E_USER_WARNING] Cannot call method isFirstPost on a non-object (NULL) (src/XF/Template/Templater.php:1285)
help with Loco Remote Maxi
After turning on the maxi, you then need to switch off the Wi-Fi on your phone and allow the phone to connect to the maxi signal.
Do you mean ‘switch on’? This link may help.
look at Quick Start guide’
I have two of these, and don't have any issues:
On my phone, I disable my home wi-fi, and then I get a lit of other networks available, I connect to the one Loco XXXX (I have now renamed it), once it is connected, I open my browser, and navigate to 192.168.4.1, the loco remote control page comes up and off I go.
The instructions are quite clear, but they MUST be followed line by line (until you know what you are doing), and it works.
@Choppercook exactly what have you done, and which part are you having problems with.
Ah that sounds better, similar to my Z21 that creates its own WiFi hub.
Hi, I am sorry but I am not very good with wiring,
I have the Maki with internal sound card, the main board power the motor?
How do I get power to the soundboard to use the sound and lights?
I have the 8-wire cable do the wire come a part?
Do I connect the main board to the soundboard and with pin to what pin
Please help
If you bought a Maxi with internal sound:
It should have come as a 'stack' of boards. - You only get horns with this option, and just plug an 8 ohm speaker to the board.
If you chose an external soundcard, was it a MyLocoSound? - This would probably have eight wires:
Two to power the card. - Can come from your battery, after the switch.
Two would go to the motor. - To sense the speed.
Two to the speaker. - So you can hear it. ;)
And two would be triggers, for horn/whistle, and 'something-else'.
Agree with Phil, I have the on board sound (which I found disappointing), but there are three boards stacked, just follow the instructions, you just need to plug your speaker in.
I contact loco remote I was told. If the red LED on the bottom green board is staying on then there is a fault, return the boards I will replace them, Apologies for the problem. top man
