Have I killed it??
andyspencer
30 Oct 2009
1,133
11
West Midlands
Just had a battery loco running around the garden which has a manual control powered by 8 low discharge AAA cells, when it suddenly stopped... Got to the loco and found all the wiring melted and the battery hissing and so hot I couldnt touch it! Its still got voltage in it but looks a mess. Would it be safe to charge?
mike
Master at annoying..
4,464
Rossendale
er no
andyspencer
30 Oct 2009
1,133
11
West Midlands
Was thinking that would be the answer :( Still not sure what caused it to go. No sign of a short before everythin melted...
bobg
3 May 2010
20,141
25
Middle Earth
Re:Have I killed it??
Was it steam outline?
If so...................................................................................... it's chuffed! :D:happy::D:rofl::rofl::rofl:
stockers
3,795
66
Nr. Ashford, Kent. England.
could be an internal short. Sounds dead to me - I wouldn't risk a perfectly good charger on it.
andyspencer
30 Oct 2009
1,133
11
West Midlands
It was steam outline, the smoke was coming out the tender thou...
Fuse and the charging socket was the next job as I was testing the setup as I'd already had problems with it. faulty pot which was replaced. Motor still operates so its not that thats failed. Either the new pot has gone or the chip. Its bolted down to a big enough piece of aluminium thou and with heat sink compound.
Rhinochugger
Retired Oik
4,246
North West Norfolk
Speaking from experience - a lucky escape where I could have caused a major conflagration
ALWAYS INSTALL AN IN LINE FUSE - FIRST - AS CLOSE TO THE BATTERY AS POSSIBLE.
I was lucky, I managed to rip out some of the glowing wires with my hands and only burnt a couple of finger tips. Trashed the battery pack, though.
Oh, the loco was indoors at the time, being charged, and sitting on a wooden worktop :banghead::banghead::banghead:
andyspencer
30 Oct 2009
1,133
11
West Midlands
Def an experience! Annoyingly the fuse holder is sat on the bench ready to go in. All my other loco's have them fitted and never had an issue. think i'll get a meter on the cells in the morning and see if their all the same or not. But it may well be going in the bin...
Anyone techy enough to tell me what the hissing was?
Rhinochugger
Retired Oik
4,246
North West Norfolk
Probably sizzling and giving off some noxious gas - nothing to worry about though :rofl::rofl::rofl:
nicebutdim
14 Dec 2009
4,694
16
Sunny Surrey (Ha)
More than likely escaping gases from within the cooking batteries. At worst hissing is usually followed by a loud bang and then a trip to casualty.
mmts
62
Essex and you dont need your passport
Sounds about right....
Best leave them outside under a tin bath till the morning (deffo not in the house or workshop.....)
mike
4,464
Rossendale
put it this way.. RUN
andyspencer
30 Oct 2009
1,133
11
West Midlands
They are currently in the kitchen. all sizzilling has long stopped now! when I ripped them out, was ready to duck and/or run for cover!
mike
4,464
Rossendale
if in dought, send wife in.... well they say women and children 1st!!:rofl::rofl::rofl:
Rhinochugger
Retired Oik
4,246
North West Norfolk
I got my battery pack to the point where the connecting tabs between each cell were glowing red :banghead::banghead:
The insulation on much of the wiring for the rest of the circuitry had melted, and the two switches were trashed.
Lighting diodes survived, loco body escaped unmarked by the heat (body was nickel silver)
Fingers damaged :brokeheart:
KeithT
190
Nr Manchester
I think I will stick with 230V AC much safer....:banghead:
