Greetings from SE Arizona
Arizona Slim
Hello! I have recently retired, and am interested in modeling narrow gauge in 1:20.3. I like to scratch build freight cars, but have never worked with such a large scale before.
Arizona Slim
Welcome to the forum Slim.
Our forum comprises of mostly Britons modelling UK and European prototypes, but we do have some North American members here, as well as others from around the world.
I'm sure someone here will have some common ground with you....
Welcome to the forum Slim, building cars can be a big job. I have a smaller European one on the go just now and another in planning. I tend to use plastic card but on another vehicle project I have used used plastic coated foamboard. I have also used thin wood as well plus for a Railcar Coffee Stirers on an inside frame made of thin wood siding. So there are many options to choose from, but do not forget the rivets! Pins can be inserted into small drilled holes. You can see that I am in the process if fitting rivets.image.jpg
Hi Slim and welcome. I’m one of the Brits living in the US. 1900’ up a mountain in North Georgia.
I’m sure you’ll get a lot of advice and help. The group like photos by the way.
If you need help translating the UK based comments, don’t hesitate to ask!
Hi Slim, and Welcome to the Forum! Like you, I model in 1:20.3, 3ft narrow gauge, but in my case it's the Isle of Man Railway. They had much smaller box vans, cattle wagons and opens, which I've modelled using 1/32" plywood, or Medium Density Fibreboard. Here they are, in and amongst some RTR and kit-builds...
