Feedback for design for my garden layout
GAP
14 Jun 2011
4,057
940
Australia
My elevated layout under construction.
it has 2 levels to reduce the base board width and to provide some visual interest the width is 630mm (25") with a width of 1Metre at the trestle area.
I am planting bushes under the layout that will be allowed to grow high (they grow at least to the height of the fence) to give some "garden' for the train to run through.
An example of some big trestle bridges
justme igor
17 Apr 2020
679
64
Netherlands Westwoud
Netherlands
Greg mentioned levels. You might be surprised that what initially seems like a level site does have a slope. I would suggest working out those slopes by driving a peg in the ground and gradually working round the site with more pegs and a spirit level. It might end up being ground level for a small section (easy access) and elevated elsewhere.
Paul
With a spirit level you can make quickly mistakes, i would advice to rent a laser, especially for distances longer than 10 meters.
And while your busy with those pegs, start in each corner and tension a string between the most outer pegs, drive at every two meters a peg into the ground next to that string, you will end up with a very level and very strait railway.
Like Greg said: go with a bridge that you can take out or with a hinge.
Best
voodoopenguin
Retired
20 Jul 2015
1,781
549
72
Blofield, Norfolk
Norfolk-Island
You can certainly make mistakes but using a 6' spirit level like I did in my own garden and checking via different routes of pegs not just in a straight line any mistake would not cause a problem. The idea of a string between the outer posts to check those in between is an excellent idea which I also thought of but after I had finished! Fortunately my layout doesn't appear to have any untoward hills or bumps and on the longest side is about 15 metres in length.
Paul
justme igor
17 Apr 2020
679
64
Netherlands
With a 6 foot spirit level you can do 15 meters, a mistake of half an inch is forgiving on that length.
But the garden of DGE looks a bit bigger, i think the longest straight track will be ~120 yards(~40 meters)?
So even if you would start in the center and go your way to each middle to work to the corners, for me would that be to tricky.
And i have some good and long levelers
I am also not used to do that kind of distances with a leveler(working in the construction), when it is longer than ten meters we always get a laser.
Also to save time of course.
And dont forget to turn around the leveler after every point you made or make sure that it is a really level leveler
38thfoot
Grand dreams; limited talent
19 Nov 2013
86
18
Hazel Grove, S Manchester
Is there a prototypical reason to have double track as I’m personally a fan of the meandering single line that I associate with MOST narrow gauge?
38
4,989
38
No reason other than heavy traffic, single line is a well used system still (even on some main lines) so if that is what you like go for it.
