paul delany
Hi folks has anyone here ever done any repairs on revo recievers I fit one the other night and smelt a bit of smoke,,the loco will drive forwards but wont drive in reverse,I'm hoping it is just a blown mosfet/ transistor?
Hello thankyou for reply I made a boo boo I applied 12v dc to the motor output terminal on the reciever to test the motors as the pickups were not good on the wheels as a test ,but obviously the circuit design did not take to kindly to seeing 12 v at the motor terminal blockVery possibly, but take a step-back.. Why did the transistor(s) blow?
If there was something that caused the motion to lock, will it happen again??
Every loco that comes my way for work. First-thing, it get's run forwards and backwards on DC, from a bench supply which has current and voltage metering. - This way I can judge how worn the mechanism is. What current it takes (no load) and, if I wish, I can stall the loco (or try to!) and see how much current will be pulled under an extreme fault.
No amount of alternative electronics, will compensate if there is an underlying problem with the mechanism.
You may 'just' have been unlucky, with a sub-standard component? But who is to say that once under load, the loco won't draw enough current to burn out more than just an output transistor.
Sorry, but..![]()
Yes it smells and there was a bit of smoke I will have to inquire the board and have a closer look,I dont suppose you have any used ex boards lieing aroundAh! Oooops!
In which case.. Can you see a blackened / burnt-out component on the Receiver, by any chance?
It might be an output transistor, but could equally well be the transistor controlling the output??
You might only notice a slight swelling in the case, or even just a dulling of the finish to the component?
Ok cheersNot Revolution, I am afraid..
The damaged component(s) could be under the heatsink? - You may not be able to spot them..
Yes indeed I have removed it and I googled the blown surface mount chip that I blew but couldint find itThe heatsink is removable:
Will do greg can I ask what are you modelling these daysgreat, let us know how it works out!
