Zerogee
Clencher's Bogleman
[blockquote]Hope no-one minds me doing this, but I posted this to the Sat 21st thread in the Coffee Lounge last night, and this morning realised that it might get lost there with the new thread each day - so I'm reposting it here as a new thread, hoping to get some comments and other folks' ideas.[/blockquote] [blockquote]It started with Tony asking a question about testing decoders...[/blockquote] [blockquote]
[/blockquote] [blockquote]Tony
Evening gents
is there anyway of testing decoders with out fitting them to a loco first please
Tony
[/blockquote]
Tony - as Mike commented, it should be quite simple to build your own test rig (I've been meaning to do one for some time, just not got round to it yet). Decoders need a load to operate while they are being programmed/tested, so what you need to make is a little setup that has a motor (any small one of a suitable voltage should do, ideally with a flywheel of some sort on the shaft so that it has a little bit of load on it), some bulbs or LEDs to test the light outputs, and a speaker if you want to test sound decoders. Some sort of quick fit connections for easy wiring up, then you should be able to couple any decoder to the test rig and check it either with your normal control/programming system or something like a Sprog if you have one.
As Mike said, ESU do a commercial one (I think Jeremy sells them) but I'm not sure if they are universally useable or if they only work with ESU decoders. Theoretically a homebuilt one could be universal, though you might want some different impedance speakers for different sound decoder brands.
Anyone on here actually built something like this already? If so, care to post some pics and write it up? I'll do that if I can ever find the time to make mine!!
Of course, if I'm thinking too simplistically and there are some problems I've missed, please tell me!
Evening gents
Tony
[/blockquote]
