The mechanic
Hello again everyone.
Having seen a "bargain" of four large cans of butane for a couple of pence more than a small lighter top-up can at my local B&M, I thought, "why not"?
So, armed with this seemingly enormous amount of butane, my first issue was that the cans do not have a threaded nozzle and require a converter. So I obtained a converter.
Next thing, I attempted to connect my " loco-boxes" gas filler adapter. All threaded together OK, no problems.
So now I attempted to fuel a loco. Turned the can upside down and press......... Nothing happened! - no gas.
Removed the can and held upright, pushed the long tube downwards as far as it would go, ....still no gas!
Looking at the tube, there is a small e-clip fitted into a groove about 5mm above the point where the tube enters the main adapter body. This acts as a stop to prevent over-compression of the tube. I removed the clip and depressed the tube - hey presto, a healthy stream of gas/ vapour came out of the tube. Problem was, it also came out of the side of the tube too!
I refitted the e-clip and everything reverted to how I started I.e. No gas!
Has anyone else experienced this sort of issue with butane cans fitted with thread converters?..
If so, how do you get the butane to issue out of the tube with the e-clip in place? And if you do remove the e-clip, how do you stop butane from leaking everywhere?
I would be most interested to hear other's experiences with this, before I end up in an all-consuming "fireball" - visions of the "Hindenburg" , DIY cremation and all that - not good for promoting the hobby in the eyes of SWMBO! - she thinks I'm a spanner short of a full toolbox anyway!
Thanks
Dave
Thanks
Dave
