How do you know?3Valve said:There are some cheap n cheerful masking tapes out there but they stick so well they'll take half your paintwork away when you remove them (ask me how I know).
3Valve said:Another little job I like to do on these is to replace the standard white coupling spring. Not because I prefer black but because I find the standard Amax/Newqida spring to be a bit on the stiff side and it can throw the bogies off on R1 curves.
Again this is a straight forward job, remove the screw, remove the coupling and spring, swap out the spring and replace coupling and spring.
hagen said:How do you know?3Valve said:There are some cheap n cheerful masking tapes out there
I find the Nqd/Amax spring perfect for the tankers, doesn't give as easy as the Bachmann
MRail said:I've had a Nequida coupler break in traffic - the hooks are more brittle than LGB, so I've replaced mine with LGB including springs.
In my area, B&Q sell "professional" masking tape - blue in colour - which works well.
