EMD NW-What?
Useless Chatbot
Hey all,
I've been geeking out on US Great Lakes area iron ore railroads of late. I'm especially enamored with DM&IR, now Canadian National. I found recently that LGB's ore jenny is a close match to the cars used only in this region, for ore and taconite that is bound for ore boats. These cars are the subject of a different project. I'll share the gory details in another project thread. The tie-in is that having ore jennies, I need some believable power to pull them. In 1:29 scale the obvious choice is my favorite diesel locomotive, the SD40-2. Painted in CN red, white, and black, I thought they would be perfect until I found that they would be nearly 3' long, each. So, second favorite locomotive, the SW1200. As a match for an ore train, that's kind of a stretch, except shunting around the yard. The closest match in 1:29 scale is the USA trains NW-2.
With a few mods, they could be pretty convincing in the role. The excellent 3D models by @manimal go a long way toward bridging the gap.
Here's the starting point. Note the unsuspecting victim lounging around. I briefly questioned the wisdom of wrecking what was a very nice locomotive. Then I came to my senses and proceeded to take it apart.
I'm doing a wireless/battery conversion at the same time. So, I got into the motor blocks to isolate the track power and found that all of the final gears are cracked. So I replaced the axles. Now power pickups and track power connections to the main circuit board are removed.
Now for the heavily modified part. I'm not partial to the CanFor SW1200s with factory dynamics, but I really like rooftop air reservoirs, spark arrestors, and weird fans. I've used many of manimal's models in this build. Some are used as published. Most are modified in some way to suit my tastes.
As yes broken plastic gears on old locos, bit of a trait with my Bachmann made ones. Rather neat conversion on that NW2, Kadee always seem to have a neat solution to coupling mismatches for me with Fn3. Is this the Manimal you have mentioned ? https://www.printables.com/@Manimal I have over the past 6 years been carrying out a program of battery/sound/rc conversions of my Fn3 roster. I got fed up and too old to keep cleaning the railheads. My 16 mm scale UK/Colonial locos come ready fitted rc/battery with sound option. It's down to that scale being one here in the UK where kit being sold is operated dead rail and mostly live steam. I have noticed we have very different suppliers here in UK/EU to yourselves in US. Who do you use ? Look forward to seeing the results.
Here's some of today's progress. I spent way too much time trying to figure out a coupler conversion that I like. This is a bit crude, but it works. That seems to be common for garden railroading.
Nice interesting job on the coupling.
I went through the same on my Bachmann Fn3 Shay. I'm still exploring US-based and foreign suppliers. My go-to lately has been www.reindeerpass.com. And yes, the same manimal.
Hey all,
If you have any interest in pre-CN DMIR diesel's then the EMD SD-9 might be of interest to you. These are available as .STL files for 3D printing in 1:29th scale using USAT motor blocks.
Thanks Doddy. I did consider that model. And yeah, I do prefer pre-CN. I also looked at what it would take to kitbash SD38s. A lot it turns out.
