I'm very interested in the Ivan bearings mounted through what I assume are Plasticard chassis sides. Having experience of one of the IP delux chassis in the past, where with very little real use, the spastic plastic chassis sides crazed and split around the bearing mounting holes and which ended up with an ally chassis rebuild using the same wheel/axle/bearings, which has run perfectly since.
Cheers
Roy H
