Now that I've gone to the 'Dark Side' of MTS operation, I decided it would be a good idea to fit a point motor to the (one) point on my portable layout, Hardyard.
A while ago, I was at my local model shop, and Keith, the proprietor, was having difficulty with a DCC point motor that he was evaluating. He couldn't get it to work, and asked me to double check his wiring.
Having read the manual and checked Keith's wiring was sound, it later transpired that this sample motor was faulty. He didn't order any more in as a result.
I thought it would be fun to operate the point on Hardyard with MTS, so I asked Keith to get me one of the motors to try. For £22.50, (I got discount so paid £20), you get a slow motion motor that is DDC or DC ready, which has auxilary switches for a live frog and signalling. The motor throw will operate points up to G1.
I thought that this was good value for a decoder fitted point, albeit one not suitable for outdoor use like the LGB ones I used on my garden railway. But ideal for under-board mounting for an indoor layout.
A week ago I installed and wired up the point at the MRC where I keep Hardyard, and last night, I connected it to my MTS2 and commenced testing.
The default address is 1, which is fine for me as there is only 1 point on Hardyard.
The motor worked okay, although I had to take it off the board and open up the slot for the drive pin, which I located through the rectangular hole on one end of the tie bar. With a bit of work with the needle files, I had the motor working reliably after an hour.
As mentioned, these are only suitable for an indoor layout, but it could be used for motors in a storge yard located in a shed.
At £22.50 each with a decoder included, this compares well with the LGB 12010 Switch drive (£21.25) and the 55024 single decoder (£43.25), or a 4 channel decoder 55025 (£74.50), and effectively each motor has the equivalent of the Type 2 Supplementary Switch 12070 (£21.30) built in too!
So you could motor 4 points for £90! I know at least one GSC member who is interested in these motors for his own shed storage yard, and I will be demonstrating mine for him fairly shortly....
