Diesel2000
Hi everyone, I'd like to get some feedback on my layout design and configuration, specifically the addition of a multi-direction reverse loop. I'm in the process of converting my layout from DC to DCC and currently have a mainline and yard as seen in the first pic - pretty simple stuff. I have them isolated according to the color codes by using 1 PSX circuit breaker for each block.
I want to expand a bit and add an inner loop that can reverse in either direction. I designed the layout in pic 2 using an LGB 12260 double slip crossover switch. I received some help in figuring out the placement of the PSX-AR units, which are the red, orange, and blue blocks. Green and yellow continue to be connected to PSX blocks. So the requirement to make this work is 3 PSX-AR in addition to the 2 PSX breakers. Does this seem correct?
I want to make sure I get this right before I start digging and laying more PVC conduit in the ground as this layout is outside along the side of the house. I plan to run a separate accessory bus to power all the switches and keep them isolated of any potential short on the mainline, inner loop, and yard.
