Cutting track
Steve
I didn’t say it was your fault, I said I was b
1 Jan 1970
29,027
285
D.I.L.L.I.G.A.F
Its not the foot wear that bothers me its the wearing of socks with them :banghead:
3Valve
Railways; Air cooled VW's; Soul Music
286
Shropshire
Steve - 24/11/2009 3:47 PM
That's compulsory when you get to a certain age apparently. :D
Rhinochugger
Retired Oik
4,240
North West Norfolk
Would you really want to see his feet ? :banghead: :(
Gavin Sowry
2,490
70
Hutt Valley, NZ
3Valve - 25/11/2009 3:28 AM
Gizzy - 28/10/2009 1:22 PM
Of course, there are some on this forum who have an alternative method for cutting track....
Angle grinder and open-toed sandles - Scary :banghead: :banghead: :banghead:
:banghead: Scary, yes. Should have one foot on the track that he's cutting. :thumbdown:
trammayo
4,680
Co. Mayo
Ireland
Woderwick - 24/11/2009 2:49 PM
Actaully, they were n't open toed sandels when he started.... :rofl: :rofl: :rofl:
But, now that they are, here are the ideal socks!
Gizzy
36,140
2,273
63
Cambridgeshire
trammayo - 25/11/2009 9:43 AM
Well that's Bigjack's Crimble present sorted then....
Budd
4 Nov 2009
57
Adelaide, down in Oar-Stralia
My preferred method is a Bosch (or equivalent) 4"/100 mm angle grinder with a stainless steel cut off wheel, these aren't made of stainless steel but are a reinforced cut-off wheel made for cutting stainless steel, it is only 1.0mm thick and cuts thru brass rail so easy. The machine is small enough to be used one handed, I fabricate all my point blades and frog vees with this as well.
Be warned, WEAR SAFETY GLASSES.
Trainman
All narrow gauge and industrial railways,
459
Auckland
In Auckland, NZ we use good quality sissors from the $2 Shop. They give a good edge on our track over the "Southlanders".
Well might duck below that parapet I built for the purpose. :D :D :D
3Valve
286
Shropshire
Cut my track using an old mitre Saw and couple of files.
orville
29 Nov 2009
28
Rainy Rochdale
Can't beat a junior hacksaw with a new fine tooth blade. :applause:
JRinTawa
Member of the Wellington Garden Railway Group
1,086
Tawa
<p>
orville - 29/11/2009 7:17 AM Can't beat a junior hacksaw with a new fine tooth blade. :applause:
</p><p> </p><p>Ah, fine blades for a junior hacksaw, mine has a rather nasty wavey blade, would be so much more useful with a fine blade, will hunt some out, brilliant, thanks for the idea. :applause:
</p>
Geoff the garden nav
Aristocraft locos & rolling stock, mid C20th to co
31 Oct 2009
96
Leicester, UK
A junior hacksaw and a fine file is all that I have used together with an engineers square and a pencil. The engineers square helps to keep the rail ends level. The junior hacksaw with a fine blade allows brass rails to be cut insitue, even on top of the rail its to be joined onto for accurate lengths to close gaps when modifying track . I use a brick resting on top of the track as a weight to hold it still. Cutting stainless steel must be difficult.
The Devonian
17 Nov 2009
1,966
23
South Hams
<p><font color="#006600"><font size="3"><font face="comic sans ms,sand">There are many ways of skinning a cat it is said. :D </font></font></font></p><p><font color="#006600"><font size="3"><font face="comic sans ms,sand"> You can knock a screw into timber with a hammer: but the generally accepted way is to use a screwdriver. ;)
Rhinochugger
Retired Oik
4,240
North West Norfolk
The Devonian - 2/12/2009 1:32 PM
wot's a screwdriver ? :eek:
stockers
3,795
65
Nr. Ashford, Kent. England.
It comes with a battery drill these days :rofl:
jacobsgrandad
1
This is getting very technical
The Devonian
17 Nov 2009
1,966
23
South Hams
<p><font color="#990000"><font size="3"><font face="comic sans ms,sand">This, I understand, is a Birmingham screwdriver. :rofl: </font></font></font></p><p> <img width="200" height="71" border="0" class="imgright" alt="ball pein" src="http://www.diydata.com/tool/hammer/ball.jpg" /></p>
Neil Robinson
579
N W Leicestershire
The Devonian - 2/12/2009 5:54 PM
<p><font color="#990000"><font size="3"><font face="comic sans ms,sand">This, I understand, is a Birmingham screwdriver.  :rofl: </font></font></font></p><p> </p>
I thought the same until I moved home nearer to Birmingham. Hereabouts it is known as a Manchester screwdriver
Rhinochugger
Retired Oik
4,240
North West Norfolk
I can comfortably assert that neither is going to be a lot of good for cutting track - much too blunt :eek: :eek:
31 Oct 2009
96
Leicester, UK
In the days of the building of the US transcontinental RR and pionnering Railroads in the the "New World" they did cut wrot iron track with sledge hammers and a specal cold chisel with a handle like a spliting axe, not so good with brass code 332 or code 250 G scale track?
