Now that wouldn't surprise me!Neil Robinson said:.. I'd put one of the four batteries in the wrong way round, cancelling out another so the nominal voltage was only 3 instead of 6! Very little range!
Definitely the handset is at fault then, and the receiver is working fine.doverles said:Sorry late answering. work plus new carpet computer unpluged , right I have put new batteries in I then tuned the handset in to my other receiver still not working,I then tuned
my other handset to both recievers that worked fine still baffled
LES
Okay Les,doverles said:Hi Gizzy I have the telescopic aerial, I will swop them over and test .will post results
thanks Les
PM sent....doverles said:thanks for that Gizzy, what I have done is put new batteries in, cleaned contacts
swoped aerials but still no joy,it only works if I wrap the aerial wire from the receiver
around the aerial on the hand set, it seems to me that there is no range on it at all
from the handset if that makes sence to you
Les
Mike,beavercreek said:Hi les
You have tried swapping the handsets to estabblish that the receiver is fine and you have also tries all the obvious stuff; new batts, aerial, frequency etc. This only leaves the fact that the handset is on the blink as Gizzy said.
If you have a strong magnifier or some strong reading glasses, have a close look at the pcb board in the transmitter. Corrossion can lurk and cause resistance in circuits. This could lead to lower power being received by the transmiiter stage and it not being able to get a good range.
A 'dry' joint would lead to intemittant fault but yours seems to be a constant one.
Gizzy said:Mike,
Les has posted it to me.
I'll have a look at it at in my workshop next week....
