funandtrains
In theory using vinegar and detergent in an ultrasonic cleaning bath should be the most effective method.
I concur that a fibre glass burnishing brush will do a good job to the rails but tricky to the inside of the Fishplates. I am looking for an all conquering easy overnight system that will do a goodly amount of rail in one hit. Well depending in the amount of juice and size of Non Metal Receptacle. But of course it may be that trying to do too much in one hit will not work so well?I'd suggest using a fibreglass burnishing brush on the rail ends. It does not take long and the abrasion is quite fine compared with a wire brush It will not deal with the inside of a rail joiner though. These, if desired, could be cleaned chemically. These tools are also useful for preparing surfaces for solder as well as for general cleaning up.
Personally, I wouldn't want the rails looking any brighter than necessary. The burnishing can be confined to the lower half of the rail, which result (short of masking fluid) can't be achieved by the chemical methods.
I have some brick acid and tested it yesterday on a short piece of track with good effect so my question is, where do you get a 4' tub so I can do the long lengths? Is it a bath, what's it made of? I have an old zinc bath in the garden but I'm sure my memory of chemistry tells me this would not be suitable. It's also still too short for the longest lengths..dont bother XXXXXXX with vinegar coke or toilet duck,,,,
i tell you now,,, brick acid is the way forward,, i got a big long 4ft tub and plonked all my track in it and sold the lot
came up like new,,
cleans it in a few hours and can be left overnight,, then wash off with a hose or dunk in another 4 ft tub
it is bloody awesome and cleans the ties too
Hoping to do a fair amount before the final laying down of the new run in the garden so guttering not suitable but something to remember for the future. The bricks and plastic is also worth remembering but I've just realised I might have the best solution already. There is a large water butt I haven't connected up to gutters and piping and a 4' length of track would not quite fit in it however it would leave enough to help lift it out and turn over to do the other end and when all done it has a tap to help drain it.Correct..
You need a non-metallic container..
For small amount of track, some old plastic guttering, would do one or two length at a time..
For a greater quantity of track:
A rectangle of bricks, and two layers of builders polythene, should do the trick??
Got SWMBO to buy the GEL, painted it on left 5 minutes, quick re-rub with a brush, another 5 minutes, rinse and finished. I recon that in 20 minutes I could have twenty lengths with clean ends and ready to connect.Thanks Jimmy, info much appreciated!
Better than leaving to soak overnight, no large containers to find; I think this is my solution to connectivity with pre-owned track.
I always use copper slip on the rail joints it seems to keep conductivity for quite a few years.My efforts at track cleaning are mainly to do with conductivity between the rail joints. I'm also cleaning the fish-plates and the adjoining rail ends.
I figure I would need upwards of 150 rail clamps; bearing in mind i am using mainly 300mm track lengths.
That adds to my overall cost and it's not even a permanents layout.
Sarah Winfield
Sarah Winfield
