korm kormsen
has anybody tried baking soda?
Are you taking the rise out of us.
Not the best facility cleaner, I hear...
Not all its' quacked up to be!
Yes it was the way he was breadDid you really knead to say that, David...?
I hope no-ones finding these bread puns a pita!I thought he was just loafing around - he could have just rolled over, but instead he's trying to butter us up.....
You picked the exact opposite of an acid... acid does work in oxidation...
No one has suggested a small wire brush.. Either manual, or in a Dremel-type tool??
Using 'acid' is a bit like watching paint dry..
Well I had heard somewhere else that Vinegar needed some salt, now I know why Chemistry to create Hydracolic Acid! Next experiment but still need to try the real thing.Hmm... I find that the acid cleans it almost immediately... perhaps you are using too weak of a solution..
Watch at 1 minute, takes literally one second. Have you actually tried it?
A former member of this site had a lovely operating US layout that I visited for an operating session (indoors layout). He used scotchbright for track cleaning totally uselesss and the evening was only spoilt by the poor running on dirty rails. Perhaps had he soaked in vinegar there may have been an improvement but not sure what SMWBO in his house would have thought and also not sure about the effects of that on plated wheels.I mentioned a brass wire brush after soaking in some vinegar for stubborn oxidization and grime. A going over with a green Scotchbrite pad works well for the rail tops but hard to get into the nooks and crannies.
A small Dremel wire brush would be good for the ends and joiners.
It's best to avoid anything aggressive that will scratch the surface because it will tend to hold dirt and oxidization more. Smooth rails are better for keeping them clean.
Phil please see my earlier post about Kilroc, very quick.No one has suggested a small wire brush.. Either manual, or in a Dremel-type tool??
I would hope its even better, I was just trying what was to hand.Jimmy, thanks to your info yesterday I've ordered myself a bottle of the gel version of the Kilrock stuff (as opposed to the liquid version you used - I figured that the gel was worth trying as I can brush it on to the exact areas I want cleaned - which is basically the rail foot ends to ensure a good connection with the track clamps).... it should arrive in a couple of days, will report back on its effectiveness once I've had a chance to try it out.....
