Evening to all. Does anyone have any experience in fitting a DCC chip or two to an analog LGB/Aster NGG13 Beyer Garratt with the original factory sound on board ?
From memory of seeing Neil Robinson's Garratt's inwards, I think you need two LGB 55021 decoders, which plug in to the boards already provided inside.
Send a message to Neil, I'm fairly certain he may have fitted them to his loco to improve its running qualities when visiting other peoples layouts with DCC (such as mine).
I suppose my main question is about what is it necessary to dismantle to allow access the circuit boards, where the decoders can be mounted, as there don't appear to be any drawings available as per other LGB loco's.
Cheers
Bob
Good idea, so would I.bridge the track pins, (brown to brown and white to white), so both units are linked for pickup. This eliminates one stopping while the other is driving if it hits a dead spot. I usually use one XL decoder as well so that saves space too.
Sorry to revisit this thread. The instruction in the loco's manual says you need 2 x 55021s and 1 x 55026. My question is, what is the configuration for using these?
