Chipping an LGB 24430 Zuos
Capito is an easy conversion like you say. In fact most GE 44 111 s are easy.The difficult bit is the older GE 44 11s. I would also advise not using two LGB chips but go for a MTS3 or other 3 amp chip (my preference would be Massoth XLS) and split the load. I had this recently with my Crock one bogie running faster than thhe other which caused problems hauling trains. MTS 3 solved the problem Also don't use the LGB drawings as gospel. Some do not match the model
bunnyrabbit03 said:
Using the Zimo 695 might be the best option, really, if you are replacing the electronics - probably advisable anyway rather than relying on old electronics. You can connect the servos directly to the Zimo without the need for an external 5V regulator.
I was under the impression that LGB Ge 4/4 III panto movement was made by motors, not servos. Ref. the link I put in a few posts up.
