Cheap & Cheerful
Chris Vernell
Tortoise
1,823
77
Nepean, ON
Canada
Moving slowly onward with my battery/RC conversion of a Bachman L’il Big Hauler tender loco.
Today I decided to do something about the chimney, which Bachman placed aft of the cylinders — probably to accommodate the enormous headlamp. Since I like neither the lamp nor the chimney position, I got out the saws
and removed first the lamp
And then the chimney
which can now be lined up with the cylinders. Much bodging and filling to come.
I also plan to remove that horrible bell.
And I did.
Chris Vernell
Tortoise
1,823
77
Nepean, ON
Canada
First step in filling the holes in the boiler / smoke box.
10 thou styrene sheet applied inside the boiler.
Checking that the chimney base fits. I’ll glue it in place tomorrow and start filling in the holes with black Milliput.
Chris Vernell
Tortoise
1,823
77
Nepean, ON
Canada
Turning to the tender
Two lengths of 3/8 ABS angle to keep the battery pack from shifting side to side.
Like so.
Chris Vernell
Tortoise
1,823
77
Nepean, ON
Canada
Puttying up:
Black Milliput applied, dried and sanded, plus a spot of Vallejo white putty to fill in a slight dip; easier than mixing more Milliput.
I sawed the fancy cap off the chimney because a plain stovepipe is more suited to an impecunious branch line.
I removed the number “button” from the smokebox door; the hole will fit an LED headlamp nicely.
Rattle-can primer will reveal my errors and omissions. Eventually the loco will be black.
Chris Vernell
Tortoise
1,823
77
Nepean, ON
Canada
Boiler primered.
Looks so much better in one colour.
I have noted places where more filling and sanding is needed. I’ll do that Saturday after the primer has cured.
Meanwhile …
Chris Vernell
Tortoise
1,823
77
Nepean, ON
Canada
Rain has stopped outdoor play, so I descended to the crypt and took up the r/c project tender.
I plan to use Peter Binnie coupling hooks, so the tender needs a deeper buffer beam to hold one. Out with the black styrene sheet and the cutter and …
Reinforcing plate glued to tender body.
Full-width beam glued on.
Right way up.
1-inch coupler mounting height established (yes, the rule is one inch wide; cunning, eh?).
However, I am not going to rely on the glue joints to take the coupling strain. Small hex-head bolts are on order to hold the reinforcing plates to the tender body. Naturally, I don’t have the right ones in stock.
Chris Vernell
Tortoise
1,823
77
Nepean, ON
Canada
Soldered up the loco connection:
I am tempted to scrag the loco’s previous owner. Apart from the burnt-out motor, several bits are missing, such as the hook to connect the loco to the loop on the tender.
The motor has been replaced. Other bits will be fabricated.
Dark thoughts will be thought.
Chris Vernell
Tortoise
1,823
77
Nepean, ON
Canada
Tiptoeing onward:
“Liquid tape” insulation on the soldered wires.
Connector in place. I sliced off the footboard; the remnant supports the connector.
Peter Binnie buffer/coupler temp fitted to the sliced remnant of the front footboard.
Front view.
Tested the mech on rollers with a 4S li-on battery; runs nicely.
Monday is supposed to be dry day, which gives me a chance for more rattle-canning before re-assembling the loco body.
Meanwhile, I have to piece together the battery/rc gubbins in the tender.
Chris Vernell
Tortoise
1,823
77
Nepean, ON
Canada
More rattling:
I must visit the craft store to see what they might stock in the way of coach colours. My ancient allegiances say chocolate and cream, but an overall maroon would be easier. With apologies to Zorro, masking is not my forte, nor even my piano.
FatherMcD
13 Mar 2014
386
35
Idaho
United-States
More rattling:
Watching with interest! I have a few of these floating around. (Engines and assorted wagons/coaches)
Chris Vernell
Tortoise
1,823
77
Nepean, ON
Canada
My order of 00-90 bolts arrived and I was able to reinforce the adhesive joint on the tender buffer beam.
I’ll rattle the black can on Sunday when the rain will supposedly go away.
I’ll remove the Peter Binnie coupler before painting. I have to find my bottle of red paint that I carefully put away. Where, oh where can it be?
korm kormsen
298
Paraguay
oh, yeah...
To put something, where it is safe and easily found.
It doesn't disturb me, that it then will be found in the last place, where i look - what disturbs me is the number of wrong places i look before.
1,704
It's always in the very last place you look
3,528
oh, yeah...
I resemble that remark! :(:rolleyes:
Madman
2,977
Pennsylvania, USA
Nice work Chris. I should have snatched up some of those L'l Big Haulers when Al Kramer was selling them at very good prices.
Chris Vernell
Tortoise
1,823
77
Nepean, ON
Canada
Threat of rain stopped outdoor play, so …
… found a bottle of Testor’s red enamel and had at the buffer beams.
Chris Vernell
Tortoise
1,823
77
Nepean, ON
Canada
Little bit of paint:
Inside cab.
And front end.
Next task is to assemble and mount the r/c gubbins in the tender. This requires a soldering iron, steady hands, and eyeballs that focus. I have the soldering iron.
