Can I update eMotion XLS using DiMax Central Station
NeilRhB
Hello :wave:
On the Massoth Website for the eMotion XLS it says "Once again we would like to point out that sound- and software updates can only be performed with the DiMAX PC-Module (8175001)".
However the DiMax Updater strongly suggests that you can load through the DiMax Central Station as it says when I run it:
- Make Sure that your DiMax Central Station is connected
- your DiMax in Update Mode
- Make sure that your eMotion XLS is connected to your DiMax Central Station
So I'm confused as to whether I can load Sound files to an XLS through the DiMax or not.
Is it achievable?
Thanks,
Neil
Neil,
You need the PC Module to update eMotion Decoder firmware and sounds.
Thanks Mark.
Do you know why the DiMax Updater suggests you can?
I don't particularly want to spend £150 on a programmer!
Neil
