British Rear Lamp Positions
LGB-Sid
19 Sep 2016
2,036
1,130
65
UK
I understand the front lamp positions on British Steam Locos pre B.R. and what the lamp positions meant and their color, white in General. but I have a question on rear lamp positions, I know they were on the last wagon, so as the train passed a signal box if there was no red lamp the signalman knew there could have been a un-coupling and a lost piece of rolling stock in that section ?.
If I fit a red light to the rear of a Loco itself was there any conventions for their placement, like the front lamps ? or was it just stuck on the nearest bracket :) This ignores the Loco running in reverse as it would then be a white Lamp / Lamps , following the position rules. I want to hard wire a red lamp to the rear of my Stainz bash and just trying to decide where to put it. I know about rule eight :)
3,521
I would mount it either centrally. - Covers all situations..
OR,
To the 'off-side'.. ie. nearest to the 'six-foot'..
But that is just me.. :)
There again, just how many Stainz were/are running on the 'British' main-line? :p;)
dutchelm
176
N Somerset
You can fit it anywhere there is a lamp bracket.
LGB-Sid
19 Sep 2016
2,036
1,130
65
UK
OR,
Its a Stainz bash it no longer looks anything like a Stainz it's now very British :)
4,991
Just reviewed a couple of vids on this. Would appear that near side IE Left facing direction of travel is the norm logical I guess as that would be the safest access in the majority of cases with a double track line.
casey jones snr
20 Apr 2010
11,944
7,486
73
Charnwood Forest Railway. Rothley. Leics.
England
I think it rather depends on what sort of railway you are trying to depict. Standard gauge and the big narrow gauge railways certainly have their rules on where tail lamps are fitted. On most small narrow gauge railways the use and positioning of tail lamps was or is a matter of local custom. A few railways didn’t even see the need for tail lamps.
LGB-Sid
19 Sep 2016
2,036
1,130
65
UK
Thanks for reply's , I sort have gone down the Standard gauge looking route now with my railway so was curious what the rules was for rear lights , I found lots of information about the front light positions and what they told a signal man as the train approached, interesting what you can learn on the internet :) but couldn't find anything about rear lamp placements so was curious before I drill holes in the cab body to get wires to a lamp :)
casey jones snr
20 Apr 2010
11,944
7,486
73
England
During my days working for BR the tail lamp was placed on the rear right hand side of the last vehicle. This applied to coaches and vans, Guardvans had specific rules for placement of lamps.
4,991
Sorry to be pedantic Paul but looking what way And what Region? See my notes on post #5. Though the examples that I referred to were in the West Somerset Railway former GWR. We know that they did do things differently!
1,696
60
I don't think I have seen a red light on a locomotive, I assume they must have been used, especially for push-pull working and light engine movements
casey jones snr
20 Apr 2010
11,944
7,486
73
England
Jon, London, Midland Region. If you were stood at the rear of the train facing towards the locomotive, the lamp would be positioned on the Lamp bracket bottom right of the last vehicle. However I note that at Leicester London Road Station, guards and shunters would place the rear lamp on the bracket nearest to the platform.
4,991
Interesting Paul, looks like anything goes! Though I bet there was a rule somewhere, working on the Railway I am sure that you would have come across them (not necessarily re Tail Lamps). I was glad to see the back if them even though not fully passed out for Rules and Regs.
casey jones snr
20 Apr 2010
11,944
7,486
73
England
From observations of operations at the GCR all passenger trains have the tail lamp on the right hand bracket of the rear coach.
Flying15
12 May 2015
325
307
London
On loose coupled/non fitted freights there would often be lamps on the sides of brake vans
I think white forward / red to the rear
Not absolutely sure on the white
The reason for them was so that loco crews could look back to ensure the train hadn’t divided
Snapped couplings were a big risk in starting or taking up the tension on particularly heavily loaded loose couple freights
I think there were particular rules too on four track running lines on which sides/both ? Were lamped
Light engines would have a red tail lamp, I think side/centre was a matter of ease for the fireman
Station pilots at big terminals usually had four lamps a red and white on each buffer beam
In black and white photos this is often confused for express passenger positioning but clearly wasn’t seen as such in reality
dave snape
21 Dec 2014
38
west midlands
an unfitted goods train would carry 3 lamps on the guards van,1 on each side of van ,& 1 in middle , all showing red lights. if the train was put in a loop the right hand tail lamp would be changed to white.any train passing it would know that it was not on the main line.
