steven large
USA G SCALES OF 30 TO 50S THEMES.ASLO KIT BASHING
awesome...THT IS BETTER!!
Richie said:Just finished weathering the Dozer today don't have a air brush like Mel so used a mix of paints on a sponge seems to have worked well followed with some weathering powders for rust . Have also added a bit of undergrowth to areas which might get caught up with in the woods and on the deck of the flat car![]()
Just need to find some chain to hold the dozer in place job done![]()
Hi PeteMR SPOCK said:|Blimey Richie, thats well worn and battered, remind me not to lend you my banjo'well done look pretty convincing maybe the seat needs wearing in tho'Richie said:Just finished weathering the Dozer today don't have a air brush like Mel so used a mix of paints on a sponge seems to have worked well followed with some weathering powders for rust . Have also added a bit of undergrowth to areas which might get caught up with in the woods and on the deck of the flat car![]()
Hi Stevensteven large said:richie...hw many inches in lenghts? widths? height pls? thks u...p,s,can u measure it for me? thks u..in case i think my bulldozer are small!!!...what scale? 1-32th and ?
Dave Hub said:Just caught up on the threqad, that is a great job Richie, It looks awsome now its weathered.
I think a rake of 20 of them is needed now.
CoggesRailway said:nice mate.... one little observation, the blade tends to be polished in appearence from use..... but very good still.
Cheers Mick for the kind commentstrammayo said:Looks the bees knees! Nice job all round![]()
Hi RossROSS said:Just seen a very good use of a spare flat car...turned into a gondola by use of styrene strips with slightly bevelled edges to make the grooves.
Sides and ends 3 "planks" high and the whole fitted with strakes. Nice. Should take an evening to do.
Richie said:Hi RossROSS said:Just seen a very good use of a spare flat car...turned into a gondola by use of styrene strips with slightly bevelled edges to make the grooves.
Built a low sided gondola not too long ago from a Bachmann flat car using wood strips rubbed down with sandpaper to give a well worn look .
